1 - 9 of 9 Posts
Stock Twin 6 spd King
Curt,
I need a quote for the following
6 speed TRD LSD
Diff side bearings
Side seals and O-rings
Both Pinion bearings
Pinion Seal
Crush Sleeve
Pinion Nut
FIPK sealant
Vent for top diff cover
Anything else I missed?
Matt
Super Moderator
PTR04-00025 TRD LSD INTERNAL UNIT[CARRIER]. LIST 990.34 COST 871.52
41201-80055 3.27 JDM GEAR SET [ RING/PINION] LIST 676.00 COST 520.00
[ includes ring gear/ pinion gear/ nut / bolts/ crush sleeve/ pinion seal]
41201-80058 3.13 USA GEAR SET [RING/PINION] LIST 1008.12 COST 769.00
REBUILD PARTS:
90179-28006 pinion nut list 3.34 cost 2.55
90311-50018 pinion seal list 24.69 cost 18.86
90366-38009 pinion bearing list 68.02 cost 51.93
90366-50039 pinion bearing list 109.03 cost 83.25
41231-14110 crush sleeve list 10.77 cost 8.23
90366-54014 side carrier bearings list 59.10 cost 45.12 ea x 2
96721-31110 side carrier cover o rings list 4.52 cost 3.44 ea x 2
90311-45013 axle seals list 30.44 cost 23.24 ea x 2
00295-01281 FIPG sealer list 22.98 cost 17.36
__________________
90930-03127 PLUG, BREATHER LIST 10.75 COST 8.20 SPECIAL ORDEER
Thanks for listing everything. I sure hope I don't need the ring & pinion! Do you have everything except for the breather vent in stock?
Super Moderator
Ptr04-00025 Trd Lsd 6 Spd List 990.34 Cost 871.52
41201-80058 Final Gear Set List 1058.51 Cost 790.00
90366-50039 Bearing, List 114.46 Cost 87.39
90366-38009 Bearing, List 71.42 Cost 54.53
90366-54014 Bearing, List 62.05 Cost 47.37 Ea X 2
96721-31110 Ring, O List 4.74 Cost 3.62 Ea X 2
90311-45013 Seal, List 31.32 Cost 23.91 Ea X 2
00295-01281 F.i.p.g., List 22.98 Cost 17.36
Boost Addicted.
Sorry if I hijacking this thread ... Are all these associated parts MUST when installing the TRD LSD or they are optional ?
Super Moderator
ABOVE ONLY NEEDED WHEN YOUR NOT REPLACING THE RING AND PINION
Boost Addicted.
Sound Great ... They are in my car plan list ... and when the time come I'll get them form you.
Many thanks,
MK
1 - 9 of 9 Posts
