21 - 22 of 22 Posts
Discussion Starter · #21 ·
Saw a similar failure on a different platform. The fork was bending and killed the clutch only (thankfully). It was a stock clutch release fork and the higher rated pressure plate killed it.
well, now I have a bmw 530 six speed transmission. Swap is cheaper than a v160 or CD009 transmissions. This weekend I will finish the work,we will see if everything is ok.
Discussion Starter · #22 ·
Update.
bmw transmission is very smooth but is very very noisy! I dont know if cd009 transmission is more noisy but if you increase idle engine speed to 1100 rpm. noise goes away. I think this is because the stock flywheel is dual mass, PMC flywheel is aluminium And cannot absorb vibrations.
But shift feeling is incredible,highly recommended.
21 - 22 of 22 Posts
