SC61 Powered 90T
if the car sits overnight and it is really hot outside in the morning it is having problems starting.
at first it will crank and crank and than start for a second and die. than start again and die quickly.
than it will start and kinda miss fire for a few seconds and than run fine.
could this be a problem with the cold start injector messing with start ups on hot days (90+) or on hot days could it cause the valve seals or valve cover gasket to leak oil on plugs??
when it is cool out the car starts much much better.
SC61 Powered 90T
well once it starts usually the rest of the day its better but if it sits for a little while, it may not start the first time but usually the second.
besides starting problems, the car drives flawless and boosts great.
SC61 Powered 90T
fuel pressure should be ok but i dont have any way to tell (stock everything right now) i have a walbro and aeromotive afpr that i need to install
can i just disconnect the cold start to see if it helps with the problem or would that cause other problems?
