I'm posting this from the mkiv discussion. When I drive with the ac on the car tends to stall out when the clutch is pushed in. Ok here are the idle setting:
Hi idle car speed 220 MPH
Hi idle rpm offset 100 rpm
High idle wait time 2.0 S
Idle off if TP over 1.17%
Idle on if TP over 1.56%
Idle FB above 400 rpm
Idle FB below 1800 rpm
Idle A/C load comp 1.95%
A/C on delay 0.00 S
Also, the laptop connects every third time to the aem, but it goes online, offline over and over. I'm using a Belkin serial to usb connector. Is this the problem? And what is the best connector out there?
A/C on delay 0.00 S
