the only way to inspect the turbo oil seals, is to disassemble the whole turbo. but if you want to do a quickie, check both of the compressor & turbine wheels and see if theres alot of carbon/oil buildup around the blades. if its wet, then its most likely that it has a bad seal.
aite, peace.
aite, peace.
