I'm running one of reg's old fuel reg, lex AFM, removed reg's screw and put the lex stock screw back in to stop hitting the fuel cut. (@.9 bar), 560'S, .040 over JE pistons, 3" ex. no cat. Stock tubro, auto trans.
At 1.2 bar the temp is 675 C, after the turbo at 30 # fuel presser.
More air or less fuel ?
Any suggestion would be much appreciated.
Dale
[email protected]
Dr Wheelspin Rh.D.
675F is super ultra mega rich or super ultra mega lean. You've got some really serious problems with your car, either that or you're using a really crappy EGT gauge or your EGT probe is tapped in the wrong place. I run ~750C at the same boost level, that's 1382F, and I'm still running really rich. I suggest you stop boosting until you figure out what the problem is.
