1 - 4 of 4 Posts
What kind of turbo kits do you have installed? Did you install it yourself? What stage is it? and when you do install an aftermarket turbo, do you have to install other things?
Pieced together Budget kit.
Installed by myself.
No mentionable stage.
I installed the single b/c the stock turbos couldn't hold high boost.
Pushing worn stock fuel system along with everything else stock except TRD clutch made
480 rwhp @18 psi.
Super Moderator
The SEARCH button is your BEST friend. Use it. You will not be sorry.
Ken.
Ken.
True statement. :) However, don't get discouraged because you're told to search. There's tons of information about kits that will come up. When you're done searching I'm sure everyone would be more than happy to answer any specific questions that you may not have found the answer to in your search. Good Luck!
1 - 4 of 4 Posts
