FIX-R upper
Driving around i almost never go into boost.. it never goes out of -4psi inless i put the gas in about 1/3 and take it to 2500+. Is that normal for a full stock 7M? also if im in 5th @ 70 and drop it down to 4th @ WOT it doesn't even want to boost at all!! (3.7 rear end gearing if it matters). But if i launch it and go though the gears shifting at ~5K there seams to be very little turbo lag. :wtflol:
Also i get 4-5 psi.. i think i have ether a boost leak or i need a new computer, buy that i mean if i leave the car sitting for a day it wont start and if it does it runs really wired for about a min then runs and idles just fine. And if it doesn't start pulling the EFI fuse or disconiecting the batter doesn't reset the comp.. only unpluging the ECU.
DDDDUUUUUBBBBBZZZZZZZZ
1. Boost Leak
2. Wastegate flapper door stuck open
3. Weak ass wastegate, try shimming it
Ludicrous speed! GO!
Definitely a boost leak. On my automatic, if I get into the gas even just a little, the stock boost gauge will start to show signs of life as low as 2300 rpms.
FIX-R upper
suprafly1986 said:
1. Boost Leak
Well back to work!!, thats what i first thought but i needed someone to tell me that.. need it as a dialy driver.
