1 - 11 of 11 Posts
Factory RSP Hardtopper
Hey Curt some members around told me to get with you about the center console assy from the radio to between the seats. The car is an automatic and was hit in the side and broke all the mounting tabs. I need the armrest console and all the plastic around the transmission tunnel. I also need all the piping and couplers for a set of stock twins. I have the 180 degree pipe on the back turbo but nothing else. I have a greddy front mount so I don't need intercooler pipes just everything leading to them. I also need the oil pipe from the pass. side of the block to the turbos. Thanks in advance for all the help.
15474, 15472, 15417x2, 17173, 17198, 17861, 17341Fx2, 22250
15474-88401 Pipe, List 33.12 Cost 28.28
15472-46010 Gasket, List 3.97 Cost 2.94
15471-46010 Gasket, T List 2.40 Cost 1.77 X 2
17173-46040 Gasket, E List 30.93 Cost 22.87
17198-46010 Gasket, E List 22.56 Cost 16.68
17861-46050 Connector List 81.51 Cost 60.27
17341-46070 Hose, Air List 33.04 Cost 25.55 X 2
22250-46030 Meter List 568.53 Cost 488.48
Thanks for all the help Curt. I will call you in the middle of the week.
Curt Aigner said:
Pick Out Whats Needed From This Pic:
15481a,b,c
15482a,b,c
Thanks Curt and I also need both side windowrs with gaskets (behind door) and an ignition tumbler and door locks with matching keys. Thanks Mike
69005-14690 Lock Set List 357.99 Cost 272.72
62710-14270 Window Rh List 219.77 Cost 162.51
62720-14270 Window Lh List 199.75 Cost 147.71
15481-46020 Pipe, List 59.39 Cost 46.37
90401-12009 Bolt, Union List 10.17 Cost 7.86 X 2
90430-12026 Gasket List 1.18 Cost 0.87 X 4
15482-46011 Pipe, List 71.71 Cost 61.50
Discussion Starter · #10 ·
Does the lock set include the hatch? Also, If I give you my vin can it be reinscribed in the glass. Thanks.
1 - 11 of 11 Posts
