Check engine light came on and looks like I have Code 34 (Turbo Pressure Malfunction) and Code 35 (Turbo Pressure Sensor Circuit). Dug this up for Code - 34:
Code 34-
turbo pressure malfunction
All conditions below are detected continuously for 2 sec or more.
(a) manifold absolute pressure: 200kPa, 29psi or more
(b) throttle valve opening angle: 20 degrees or more
(c) engine speed 2,400 rpm or more
Trouble area
-Acutuator (for waste gate valve)
-short in vsv for waste gate valve circuit
-ecm
Any suggestion before I try to tackle this problem? Any help would be appreciated.
As far as code - 35, I'm thinking of just replacing the turbo pressure sensor. A forum member (C Reed) had the same code and symptoms (stalling) and replaced the sensor which worked out for him. But, any other suggestion would be appreciated. Thanks.
Code 34-
Trouble area
-ecm
