·All Lexus sites that I have found suck when it comes to tech advice, so I come here.
I have a 1992 Lexus SC300 5-speed with 117.8k miles on it. The motor is in great shape, but it does smoke a tiny bit under hard acceleration. I want to turbocharge it. I will most likely re-ring the motor to stop the smoke, and then get a kit. Since the SC300 and the NA MKIV share the same, 2JZ-GE motor, what kits should I look into? Should I consider building the bottom end while it is open? What am I looking at pricewise to build the bottom end? Can you guys link me up to some sites with the products?
Thanks!!!
Thanks!!!
