·I would like to know if I can use the HKS fuel pump for MKIV and the stock fuel pump together insted of two stock fuel pumps?
would be be any trouble to get a braket for twin 300zx pumps? and also are they as reliable as supra pumps?ekool said:The 300ZX pump is an upgrade to the stock supra pump as well. Those are much cheaper then the HKS pump, might as well go with it?
You can you both pumps with no problems at all. I have that setup in my car...both pumps are the same size.S-SPEED said:I would like to know if I can use the HKS fuel pump for MKIV and the stock fuel pump together insted of two stock fuel pumps?
You mean to say that the 300zxTT fuel pump actually flows more that the stock supra pump? I was under the impression that it was the other way round.ekool said:The 300ZX pump is an upgrade to the stock supra pump as well. Those are much cheaper then the HKS pump, might as well go with it?
