·1. After adjusting my clutch pedal, I tried disconnecting both of the harnesses that plug into the assembly hoping to bypass the need to depress the clutch to start the car. Neither worked and I would still like to skip the need to depress the clutch to start my car, how can I go about doing this?
2. Lucas Engine/Tranny adative and BG/GM Syncromesh tranny fluid:
Reviews? Good product or something the MKIII crowd stays away from? I used this product in my DSM to ease the lifter ticking a bit, and it worked nicely. I would like to add it to the 7M to help ease a bothersome oil leak and just for lubricating insurance. Are engine addatives something that you guys generally shy away from or welcome with open arms?
And BG/GM synchromesh synthetic tranny fluid. I would like to run this in my tranny as well (another product often used with DSM's and their anything but smooth tranny's). redline is used often in the DSM tranny's, X-fer cases, and rear diffs, but I think I would like to exclusively use the Redline product in the rear diff only, and if possible use the BG/GM synch. in the tranny (BTW: what is the fluid weight needed for the diff and tranny?).
Thanks...
Thanks...
