1 - 13 of 13 Posts
7M Love
Is this for the entire car or just the engine?
If it is the entire car, look under the spare for signs of water pooling / used to be pooled. Also, look under the plastic on the hatch, might have some rust in there due to hatch leaking. If it is a targa top or sun/moon roof, look around the seals and down on the floor under the carpet.
trunk is bone dry no signs of any water.. i'm asking because last night it rained and this morning i opened the hatch and water started dripping down from what looks like to be that plastic interior peice thats bolted to the hatch, but i could b wrong.. i guess since the trunk is bone dry i shouldn't worry about it?? maybe the water was from somewhere else?
smthing beautiful in life
any suggestions on how to find out the problem once my under-spare area is full of water?
My hatch will do the same thing. Also my buddie's does as well accept his setup is f-ed up; mine is perfect. So I think it normally just gets stuck in there somehow. I however have no hatch leaks.
As far as the leaking spots. I have reason to believe that my trim is leaking just below the tail lights being that the stud that holds the trim to the metal has rust driping down it and my spare well have a layer of rust along the outside of it.
Check the Hatch weather stripping for tears/rips. Check the carpet and other interior pieces for signs of water damage and maybe that'll point you in the right direction. Good Luck with that
Well, here are some pictures...
The loose rubber in the last picture probably could cause that leakage... And I dont have stock carpet, the trunk is custom made, but no wet spots on the custom made cloth either.
I suspect the leaking could appear in the 2nd picture. Is that so called under-taillights area? When my trunk is all set up and tidy there is a gap over there that could cause water to flow under the spare tyre and no wet spots on the cloth... :dunno:
Ive just washed my car and realized what's the big deal is.
I was right saying that the second picture is the correct problem description. The water gets there with a narrow stream of water. That sucks, but probably it can't be helped?
Im gonna deal with the rust in the spare-well and leave the the holes open... Some of the audio lines goes through there so I don't wanna have a lake again...
Or any other solution?
Emmm, the sealing place should be found under the blue plastic and the body? That location I have just marked at the attachment, right?
Just unscrew the plastic and go with some kind of seal material... :dunno: I believe the spot is at the middle.
1 - 13 of 13 Posts
