1 - 20 of 139 Posts
JZA80
Hello and welcome to my build thread, ill be updating this thread with pictures and all work/modification that gets carried out as a reference for other people who might find information in this thread usefull for there own builds.
Im from Australia i used to own a R32 GT-R but secretly always wanted a supra so i sold off my gt-r and purchased my current ride. Its a 1995 Supra RZ with the factory big brake kit, b03b diff and 6 speed manual.
Heres a list of mods that have been carried out so far (from what i can remember)
Heads:
Washed and Cleaned
Hardness Tested
Port IN & EX Ports
Polish Combustion Chambers
Face Milled
Valve Seats Cut
Valve Clearances Set .010"
X24 Milled Cam Tunnel For Cam Lobe Clearance
X24 Shimless Buckets
Kelford Cams 282/286 Duration 11.00mm Lift
X24 Ferrea Valve Stem Seals
X24 Ferrea Stainless Valves (Stock 2JZ Size)
X24 Ferrea Bronze Valve Guides
Ferrea Dual Valve Springs
Ferrea Titanium Retainers
Ferrea Collets
Bottom End:
Nitto forged pistons 20f
Nitto I beam rods
ARP main studs
ACL race bearings (rods & main)
OEM water pimp
OEM oil pump
New Welsh Plugs
Series 2 RZ Sump
Turbo & Cooling & Fuelling :
Forced Inductions modified Borg Warner 69mm s369 SXE 1.00 a/r
6boost Manifold
Turbosmart 50mm wastegate
Turbosmart Raceport BOV
Hypertune Plenum
Hypertune 90mm TB
Hypertune Billet fuel rail
Hypertune FMIC with billet tanks
4inch Dump Pipe
4inch Exhaust
4inch Magnaflow tip/muffler
Koyo R-Core radiator
ID2200cc Injectors
Triple Walbro 460 in-tank pumps
Thats all i can remember at the time being ive probably forgotten a few things.
This is how it looked when i first picked him up.
Question to suit.
Lots of nice Australian made parts ;)
Very nice build, man.
JZA80
Picked up the engine today its ready to be assembled
Installed my new wheel and carbon ganador mirrors
Question to suit.
Doing it right! More photos of that billet intercooler :)
Where did you order the Work meisters from? :) love the build.
JZA80
Discussion Starter · #19 · (Edited)
I got them from jessestreeter.com, i dealt with him directly. Good communication no mucking around and he ships world wide. I see that your running the same turbo as i am, how are you liking it ?
Thanks for the info, as of right now my car is not running. I am hoping here in the next couple of months having it wrapped up, you can see my build thread in my signature :). You'll probably be running before me :p.
1 - 20 of 139 Posts
