Top Secret
As far as I know you can replace it. I dont know where you would get the new one from but you should be able to replace it. Try the stealership and see if they have it.
!black
U joints on the NA shaft are non-serviceable.
However... you can remove and replace them (you have to do a little grinding and some hammering, easier if you have as press), but you will need to lock-tite them in. Regular 1" joints fit fine.
Search for non-serviceable joint removal (for a volvo IIRC) and the writeup is exactly the same.
Scotch Scotch Scotch
Thanks for your responses guys, if anyone else has any information PLEASE post!!
Thanks!! - Bryan
