1 - 12 of 12 Posts
Hey, Im installing a uego wideband on my 88 supra im just curious if anyone can help direct me to hook it up, i have a hole in the exhaust to put it into, but im curious about the power source. Someone said the ecu, but id like to make sure.
If you have any info to help me install it that would be awesome cause any mechanic ive talked to or person who has done it b4 wants 500 bucks.
tap off the 12v that feeds the cigarette lighter, its the easies and most convenient place to tap power from
1.5JZ Turbo Supra
i just installed my LC-1 and used the Cig lighter plug. Make sure it is 12v switched.
whatever you do, don't tap into the radio power feed. My gauge bounces to my music, making it useless, unless the radio is turned all the way down :run:
1.5JZ Turbo Supra
lol! Yea radio i would stay away from as there would be some sort of interference.
67mm of pleasure
IDK what you guys do, but I always use my TEMS switch, since I have upgraded my suspension. I personally know of several cars who use this method. Its a good 12+ switched.
^You can also use it for your stock pcm inputs as well. This is convenient for those who dont want another oxy sensor added to the ex sys.
I Love Lamp...
Never thought of the TEMS power... thats a really good idea.
So I’m running stock ecu, do you need a standalone to hook this up? Do you need to wire anything up besides power/ground/o2 sensor and what gauge works well with it. Sorry for all the questions I’m new here.
1 - 12 of 12 Posts
