21 - 28 of 28 Posts
4 T's and an X
I should be getting my ecu back next week. I had all the caps replaced so we will see.
My issues were hard to start, then when it did, idled high (1800). I could not press the gas pedal without it wanting to die. I also could not do the paper clip trick as the check engine light would not illuminate on accessories (before start). Once started, the check engine light was on. The technician at Toyota said that once he grounded the computer, the check engine light would illuminate.
Just providing info in case someone has the same issues later.
4 T's and an X
I sent it to Relentless Motorsports in Texas. Pricing depends on if there is damage to the board. Starts at $200.00
Administrator
saw his post on IG, must have been your ecu. Cool to see someone out there that can make the repairs.
Discussion Starter #28
Okay new development, turns out I didn't adjust the TPS properly. So the idle was so bad....it was jumping between 1k and 2k
After adjusting it the idle was too low. So we followed this guide, adjusted the TPS and it works great.
21 - 28 of 28 Posts
