Discussion Starter · #2 ·
It does look like a valve from a thermostat.
The pin is missing from the hole, and the round disk is gone.
Wonder if those are floating around in your cylinder head somewhere?
Flush it out using the rear heater hose, see if the extra parts come out. Not a big deal, they won't make it past the radiator so it won't mess up your water pump. Speaking of which, check the top of the radiator tank, see if there are any surprises there. :)
oh man, I'm just going to get a new water outlet housing and a new thermostat. They're not that expensive.
Thanks for the help anyway!
Uh, you need to get those out of they're in the system, they'll surely clog somewhere and you'll over heat! :eek:
