ok most people dont recomend using this kit but the greddy Underdrive Pulley kit instead !
the Unorthodox
kit has 4 pullys and the greddy has 3 the greddy kit does not alter the main crank pulley!
is it ok to just use the 3 pullys from the unorthodix kit and not use the main crank pulley!
as i think this is the problem with the kit !
any ideas !
The main reason people dont reccomend doing the UO pulley set is that you lose the "dampened" pulley.. So essentially, you would just be underdriving your accessories, which is not that big of a deal.. hopefully the pullies are lighter as well.
I run the whole UO pulley set tho and have had no problems whatsoever.
Here is a pic of what the pulley set looks like tho, very sweet IMHO.
from what i have under stood its people with the auto whom have problems not the 6spd guys!with the kit!
6 speed guys have the heavy flywheel on the other side to compensate for it vs the auto flex plate which is much lighter.
Not using the stock crank pulley is a big mistake on either car IMO
thanks for th input guys!
