V A S U P R A S
Hi guys.
Im having an issue with some subs i installed (this was my first time doing this, so i may have done something to cause this.
I have 2 12" subs in a sealed box. One of the two subs makes a vibrating sound when you hve the bass all the way up and the volume louder. It reminds me of license plate vibration only not as loud.
The sound is near a screw whole where i drilled at an angle and the wood broke though to the circe cut into te boc for the sub to sit in.
Anyone know what could be happening?
I dont think i blew the sub - i had the sub out the box running and it didnt seem to make the sound
It's obviously a leak ... what you can do is fill the hole with toothpicks and glue, stuff as much in there as you can. Then redrill the hole properly. If you broke too much you can use wood filler to fix the edges. Failing this put weather stripping around the edge of your subs and this will help create a tighter seal. Otherwise new box is the only way to go.
