1 - 3 of 3 Posts
I am almost done with my big build of a NA-T engine and I have 525cc injectors now. I was wondering if GTE injectors will work if not where can I get some 850CC injectors for a GE engine?
I don't think you can. GE uses top feed injectors and GTE stock rail uses side feed. The top feed injectors for a GE are longer and skinnier they go deeper into the runners then a aftermarket top feed GTE injector. The top feeds for a GTE are shorter and fatter. You might have better luck in the NA section on where to find injectors.
1 - 3 of 3 Posts
