161 - 174 of 174 Posts
040 hardtop turbo
Are you sending speaker-level output to the amp? The amp expects line-level signals.
You have the same head unit so I would imagine so.
Also, I don't know if you guys noticed, my Metra 70-8112 harness uses pin 12 as the ground shield for the 4 line-out RCA pins, but that is incorrect. Pin 12 on the factory harness is the "fade" signal to the stock amplifier, so I removed pin 12 on the Metra harness and connected that wire to the black ground wire on pin 11.
I'm exhausted..I officially regret ever finding this stupid thread. It's been more of a punishment lol. I very cleanly re-pinned the ground to Pin#11 instead of #12 on the Metra 70-8112 for the RCA's. Result was 10 times worse.
Pin 12 is another ground, signal ground. Maybe you have a wierd integration harness. I suppose you can try 12 instead of Pin 11. It will or will not work. Pin 11 is the "common" speaker ground.
After more detective work, in Stu’s little ms paint image he has the RCA ground going to #12 even though Ishii’s schematic shows #11. So Metra’s default configuration was correct, which makes sense. Note that Stu himself may be oblivious of this because he asserts somewhere early in the thread that it should go to #11 lol.
Pic:
https://www.dropbox.com/s/xuqzn08jn5h66jo/2018-12-04 10.06.53.jpg?dl=0
Question.. why in his images, does Stu appear to have the ground wire (#11) from his metra 15-pin adapter (which goes to R6) spliced into the ground from his HU going to the chassis? (Ishii says just ground the HU straight, so does his schematic) Its the pics that show this but he contradicts himself buy saying that ground wire is tied to his RCA's but also in his ms paint pic he says to wire it to the HU directly... too much inconsistency ughh!!
Here's a link to my harness..
https://www.dropbox.com/s/pn24cfim1lpa27d/2018-12-03 20.44.36.jpg?dl=0
note: I ran a new pin for #2 dimmer and omitted #8 the solid blue power antenna wire
Thanks!!!
040 hardtop turbo
In addition to my previous post... I’m planning on ONLY using my rear glass antenna as opposed to the powered (fishing pole) antenna (I will use Metra 40-GM10 adapter harness to make the small plug a larger one) since I dont want to deal with wear and tear on the motor and in the future will probably shave it anyways.
So just to be clear, the ONLY reason to have the female 6 pin and 10 pin connector is for the power "fishing pole" antenna? because I did not install that connector (unintentionally) and as it seems everything works fine, except for the antenna raising. But, I did plug in the power antenna cable into the back of the new HU, so was that pointless to plug it in?
So.. that means I can completely delete the Metra 71-1761 (male IH1/IH2 connectors.. I noticed some of y’all call them female pins lol) right?
Master Shit Fixer
This is an issue. If you are sending speaker-level outputs to the stock amp, your are overdriving it. The amp expects line-level signals (RCA connections). In my case, the stock amp is gone and I am sending the RCA outputs of the stereo directly to the line-level inputs of an aftermarket amp. I am not using any of the speaker-level wires on the Metra harness.
Can you post a picture of the radio harness and Metra harness, showing which wires you have connected to each other?
040 hardtop turbo
Okay, here's a video of me verifying the harness against the schematics. You can stream it rather than downloading, I love dropbox.
https://www.dropbox.com/s/b7a7vsyd2hco3rr/2018-12-05 09.02.10.mov?dl=0
Here's closeup pics of the connectors and connections.
https://www.dropbox.com/s/reifouujx4wevlt/2018-12-05 09.17.08.jpg?dl=0
https://www.dropbox.com/s/avt1l5jlci3n6lg/2018-12-05 09.17.27.jpg?dl=0
https://www.dropbox.com/s/mfxzt27us0koeed/2018-12-05 09.18.16.jpg?dl=0
https://www.dropbox.com/s/xe7jbt7ofp00uek/2018-12-05 09.18.42.jpg?dl=0
SOS! :)
040 hardtop turbo
Alright well I give up. I've installed and uninstalled this way too many times.
Master Shit Fixer
040 hardtop turbo
You have the speaker outputs of the head unit connected to something (can't tell from your pictures). But they should NOT be used. You need to run RCA patch cables from the back of the head unit (not the wiring harness) to the amp's signal-level inputs somehow.
You can watch the video if you want.
Just to share, I think there was something wrong with my amp. Or perhaps a compatibility issue. I ended up bypassing the stock amp and everything works perfect.
I was lucky enough to get help from Stu, he was beyond knowledgeable and very gracious with his time. Even though I couldn’t get this working, it was worth it just to have to opportunity to chat with him.
For the record the stock amp is 40w so for those of y’all who have upgraded the front and rear speakers (should be everyone lol) and want to have a setup that’s balanced/proportionate you can very easily install a nice modern mono or 2ch amp without any permanent modifications to your Supra and power a 10000 times better subwoofer :D
If the stock amp is only outputting 40w, how was it driving the speakers and sub?
My car doesn't have a sub. Does that mean the wiring wasn't ran for it either? I don't have a IH3 connector. If I wanted to add a sub using the stock amp, that's pretty much out of the question right?
Master Shit Fixer
Poorly, relatively speaking. 40W is not nothing (lots of aftermarket head units have 45W internal amps). But even a few watts will produce sound from a speaker.
My car doesn't have a sub... If I wanted to add a sub using the stock amp, that's pretty much out of the question right?
Yes, out of the question. Add an amp for the sub, or ditch the stock amp and get one that will drive all of your speakers.
hello, my car already had a bypass with a Metra wiring harness. How do I supply power to the amp so that I can still use the factory sub? IH3 is still connected.
Take a look at the pictures I've added
In order to bypass the factory amp for the speakers and utilize it solely for the factory sub-woofer you only need the following:
  • the amp integration harness with the RCA outs (as per pic). I had an a Metra 70-8112
  • the Toyota harness with 2 connectors (as per pic) I used model WH-70-1761
Wire up as I have in the pic. Your aftermarket deck harness will wire up to the RCA harness (connect blue, red, yellow, black, blue with white strip and orange if you have an orange wire and any other wire except for the speaker output wires).
On your aftermarket deck harness, wire up the speaker wire outputs (grey pair, white pair, purple pair and green pair as per pic to the WH-70-1761 harness.
Now your ready to simply plug things in, no more cutting or crimping.
The WH-70-1761 harness will plug into the IH1 and IH2 sockets. You need to unplug whats currently in there and you can just let it rest back there. IH3 will remain as its the connection for the factory sub-woofer.
Lastly connect your deck to its harness and plug in RCA's into the deck. I choose to plug the rear speaker RCA's (green and purple) into the deck's Sub out. That way my deck could filter out the high frequencies.
247685
247686
Sorry to revive an old thread but I want to give a shout out to everyone who contributed to this, especially Stu. It was a tremendous help in installing a new Bluetooth HU in my car. Bypassing the factory amp for everything except the sub is fantastic. Big thanks!
247799
I've been bypassing my amp for ages, but today when I physically removed the amp the headunit (aftermarket Pioneer) stopped working. I'm guess that even with the amp bypassed the headunit's power source comes through the amp initially. Anyone know how to set up wiring to bypass that?
I’ll try and take a look at the wiring schematic for you. Did you use a multimeter to verify if there was voltage at the +12v wire and ground wire?
