1 - 7 of 7 Posts
upper suspension arm replacement... *UPDATE*
will I need any special tools... it almost just looks like those big nuts/bolts that go into the frame and then pop the ball joint loose... but I'm sure there's something I'm missing... I've never done any suspension work... any help is greatly appreciated b\c it gets me that much closer to getting my car back on the road...
thanx
Patrick
OK I got the ball joint separated and that long bolt loose(well got the nut off of the other side...), but I can't seem to get that damn bolt out... anyone have any tricks on getting it out... I think mine might be bent a little bit from the accident...
so no special tools are really needed... c\ I checked the tsrm and it said that one is needed to pop it out of place... but you guys think I will be able to do it without the tool... have any of you done if without the tool....
thanx,
Patrick
They're talking about a ball joint separator (looks like a large tuning fork with tapered forks), to help remove the arm from the hub. If you really want to you could rent one from any autoparts store...
Or just tap the bottom of the nut (on the ball joint) after you've loosened it a few turns.
1 - 7 of 7 Posts
