1 - 3 of 3 Posts
Is there anything I can do to test my used r-154 before I put it in? I got it from blue grass auto salvage in KY, via usedcarparts.com and supposedly it has 54,000 miles on it. It has a warranty, but I would rather not have to pull it out again.
wastegate hose is pulled
Stick a shifter on it. Row it into each gear and spin the input shaft. Watch the ouput shaft. It should spin faster for each higher gear and backwards for reverse. If there is any fluid in it, drain it out and have a look at it. Otherwise, slap it in and drive it around or take it apart for a look.
I will try that.. thanks.
1 - 3 of 3 Posts
