1 - 12 of 12 Posts
OG SF Member #603
I'm going to pick up a motor/tranny and wanted some input on how best to do it. My plan is to bring an engine lift and pick the motor/tranny up and drop it in the bed of my truck. My questions are... I have the leveler for the lift and I guess the idea is to remove 4 bolts from the block and then attach the brackets of the leveler to the block w/ the bolts. Is that right? If so, what bolts are recommended to use? Should I disconnect the tranny or keep everything intact? Should I have any concerns w/ transporting the motor/tranny in the bed of my truck.
Any input would be greatly appreciated.
Thanks.
Scott
I'd probably disconnect the engine and tranny for ease of handling. Put each on a couple of old tires to cushion them and keep 'em from grinding around on the truck bed.
yeah thats me!
when i sold my old 2jzge motor what i did was use a lift, w/o a leveler and lifted from the mouning brackets.
you will need:
1.) Lift
2.) Chain
Oh yea remove the tranny. you can lift the tranny by yourself, or have some1 give you a hand if it still has the fluid and Torque Converter (Auto) <those can get heavy.
And do the tire recommendation from above and/or use come along type strap downs.
Pretty simple, good luck.
-ian
You can lift them both at the same time and set them on old tires in the bed of your truck. It's the same as removing it from a car, use the lift hooks.
yep use the lift hook's and tires sound like a good idea didnt think of that..I drove from VA to MD with my motor in the bed of my truck with just a little bit of rope to keep it stable..Worked out fine jus had to drive rather slow..
High Performance WorkShop
Lift hooks + tires = perfect job !
but try to keep the chain tilted towards the front of the engine and secure it with a big screw driver , that'll keep your engine + tranny lifted straight .
OG SF Member #603
Thanks guys:)
I'm going to preface the next part w/ the fact that it's been over 5 years since I've looked at a 2jzgte, so......
By "hooks" do you mean the hook off the side of the valve cover on the pass. side(IIRC)? Where's the other hook(s)?
Thanks again.
fledis said:
Thanks guys:)
Thanks again.
other hook is on driver side to the back (closer to the firewall) also on the side by the valve cover..
OG SF Member #603
Discussion Starter · #10 ·
Rob,
Thanks. I figured it was somewhere like that, just don't remember seeing it.
toohipsi said:
I have the hooks in my garage if you need to borrow them, just give me a call. 410-808-4409
Matt,
I'll give ya a call tomorrow evening about the hooks.
Thanks.
feeding your habit
FWIW, when using an engine stand, do NOT use the type that has 3 wheels (from the top view it looks like a T) they are very unstable and with the turbos haning off one side, your motor will fall to the floor. Use the type that looks like a U. In other words, it has 4 wheels, and is MUCH more stable. My motor fell, and luckily a trailer broke the fall, so all I broke was my TB. Could have been much worse.
God that was awful.
OG SF Member #603
Discussion Starter · #12 ·
Don't have an engine stand....yet. Hoping to go straight from the lift to the car:)
1 - 12 of 12 Posts
