Michael,michaelvanle said:Been a while since I had the LM1. I only had it for about a month or so and I sold it. I hated waiting for the sensor to warm up.
Here's what I tapped:
-RPM
-AF
-TPS
-Boost
I was running a VPC so I just tapped into the VPC's map sensor. I was trying to tap egt from the GReddy boost gauge, but I called their tech support and they said it wasn't possible.
HotSoup : All you need to do is tap in the BLUE wire of the HKS Pressure sensor and hook it up to RPM Aux-X converter switch box (RPM converter) input. This will allow you to log the 5v output of the sensor.HotSoup said:
