1 - 1 of 1 Posts
PHR Powered Pimp Moderator
I've seen a could of guys do this to there stock twins. they remove the metal vaccum routing thing that sits above the turbos. Well i finished what i thought was all i needed to do but when i went to start up the car it turns over then dies. then i try again and it starts! but after that i tryed to press the accelerator but the car sounds like it wants to die then it revs up. i dont know whats wrong. i capped off everything that needed to be capped off and i removed my solenoids, there are no leaks. my car is bpu, ttc (temporary way). im wondering if i have to wire open the acctuators in order for it to work correctlly. I believe EVILTT has this mod and so does BOOSTT. if someone can help i would greatly appreciate it.
1 - 1 of 1 Posts
