The engine has been out of the car for more than 5 months now, and after the single and fuel installed, I have no ideas where to run them. I also have the whole EGR eliminated. Any ideas? Thanks in advance for any help.
The ones on the back of the manifold are for the EGR either cap or use as vacuum sources.
The Intake Air Control valve has 2 coolant lines. One is coming from the back of the motor and the other you can see in the second picture. It's hooked to metal tubes and is running between the middle runners on the manifold. The front one on the side hooks to the power steering pump.
1 - 3 of 3 Posts
