1 - 4 of 4 Posts
FMOS Racing
Hey there everyone;
I know that there are some posts regarding what vacuum lines and devices can be removed without too many problems. My car is going to be a track only car, so I am not too concerned with emissions, power steering or HVAC operation. One post I read said that the only things I need to run are lines for the Fuel Pressure Regulator, blow off valve and wastegate. Is this true, or am I going to run into problems that set the check engine light? Any help is appreciated
I wouldnt disconnect the Vacuum line that goes to the brake booster.
FMOS Racing
no, Ill leave that one. My realconcern is the check engine light. I was doing some more reading this morning, and it looks like I will also have to leave one hooked up to the boost pressure sensor as well.
there are a couple sensors under the intake manifold that need vaccuum lines attached to them to properly get their readings...
if you go standalone, you can rip a LOT off...
1 - 4 of 4 Posts
