D
DANKAHOLIC
·Guest
Just wondering what everyones vacuume at idle is and can this tell you if you have a boost leak?
Chris
Chris
Same here.Zerosoul said:yeh it dips..I notice it also when cruizing on highway that it goes to 23-25, only at idle the gauge shows 20.
Boost is measured in PSI/Bar (blitz meter doesn't use either for boost its like kg/cm) etc.SpdRcr0 said:what "other" numbers... there are metric standards.. either PSI (pounds per square inch) or BAR (barometric pressure which is messured in millimiters of murcury) ... so I don tknow what your tlaking about??
