1 - 9 of 9 Posts
I'm driving around town and I notice I got a little bit of smoke coming out from under the hood. I pull off and pop the hood and notice there is enough oil leaking from my valve cover that its dripping onto the exhaust manifold and burning. When I had this problem on another car, all I needed to do is replace the Valve Cover Gasket. When I searched, I read that in this car that gasket doesnt serve much purpose, and some people remove it. If thats the case, what can I do to get rid of the leak? Or at least slow it down a bit, most people seem to have a small amount of oil leaking.
Also, when I replaced my spark plugs/wires this last week, I noticed all the boots had oil on them, especially the #6 one. Anyway, back to the question, what should i do to get rid of this oil leaking problem?
Big HP = Big Downtime
Get a new set of valve cover seals. The one you are refering to thats not needed is the center gasket between the 2 valve covers. It can be removed but you have to put the allen key bolts back and torque them down. The valve cover seals are also the reason you have oil in the spark plug valley
Republican
Buy from champion... it will be WAY cheaper.
best thing i did when i had my 7m, take those allen screws to homedepot and find the right size in hex bolts, works soo much better, i had to use longer ones and use a cutter wheel to trim them to size tho :p
Anybody have the part number for the Valve Cover Seals? If I order them from champion it wants me to put in a part number that I dont know.
1 - 9 of 9 Posts
