1 - 3 of 3 Posts
Im going to be changing my valve seals next week and need to know what other parts need to be changed at the same time.I ordered the seals,valve cover gaskets,and timing belt but are ther any other timing tensioner seals or anything that Im missing.I dont want to tear it down to find out that Im missing something.I am going to replace the cam gears while they're off so Ill come back BPU ++.:D
Joe
Cam seals,2 breather hoses between the valve cover,also when you pull the cam's keep the cam buckets in order dont mix them plus when you pull the old seals out check the valve stem there might be pices of the old seal stuck to the valve guide.
o one more thing try not to scar the head where the cam buckets go in because then they wont go back in easy
hope this helps
Thanks,
Sounds like youve done this before.:) I heard it takes 10 hours.Im not looking forward to it but its the last maintenance thing I have left to do to bring the car up to spec.
Joe
1 - 3 of 3 Posts
