1 - 3 of 3 Posts
Life begins @ 30psi....
The search is not helping me much, I have the tool to compress the bucket but I am not sure how to remove the shim?
There was thread about useing compressed air and and magnet but I am not sure what would be the easiest way. I do not feel like taking the cams back out if I can help it.
Thanks,
Bob
Slide a small thin screwdriver in the little notch in the bucket. That will pop the shim loose and then keep a magnet close by to pull it out if you need :)
OCC
I use compressed air, a pick, and a magnet.
ps: How's the hand healing up? Did you get the trac elim kit installed?
1 - 3 of 3 Posts
