1 - 19 of 19 Posts
1JZ BLING!
$50 1JZ Alternator
$75 2JZ Alternator (bolt on for 1j, harness change)
$sold 1JZ Valve Covers
$50 good set of stock injectors
$25 camshaft sensor
$50 crank sensor
$100 crank pulley
$45 timing belt cover lower
$100 1j short block (block crank pistons rods)
$500 good 1jz longblock
$50 bad set of twins (for upgrade)
$50 1jz block with broken piston
$300 good short block
$200 good 1j head
JetFire
any pics of valve covers what's condition.
1JZ BLING!
Discussion Starter #16
engine (accessories are NOT included, only the longblock assembly, pan and valve covers:
do you still have the full motor (short) & (long) block. both that have no problems. thinking of building a motor. so need both top and bottom. if so how much would you sell both for.??
1 - 19 of 19 Posts
