Ok so to cut it short, I sent in my 6765 for a rebuild and upgrade to the new 66mm turbine wheel. A few days later precision called me and told me that I needed to send in my turbine housing in order to get the 66mm upgrade. I told them to cancel the upgrade and that I only wanted a rebuild because I did not want to wait any longer. The turbo came back and I installed it and went for a drive on low boost because I only had 93 octane in the tank. During the test drive I bent a connecting rod and once I pulled the turbo off to measure it, I realized that it had been upgraded to the new 66mm turbine wheel. Now I cannot think of any other reason why this would have happened other than the upgraded turbo, because it was the only thing that had changed in the car besides a fresh clutch. My car was set to 18psi but I dont know how high the boost actually got to. So let me hear what you guys think I should do as far as contacting Precision about the turbo and damaged motor.
