1 - 7 of 7 Posts
I just installed the viper 791xv.
the install is fine. But my problem is that sometimes when I go to lock/arm the car, the alarm will arm but the doors will not lock.
Me and the installer tested the voltage going to the powerdoor locks and it gets the voltage just doesnt lock them(alarm arms) but it will always unlock them. But sometimes all is well?? IDK, we are stumped.
If you used the pac-man connector then it is not a solid connection. Try splicing in directly as these are thin wires and tough to clamp on sometimes.
Supra-NA-T...Girls -Twin
^werd...sometomes...itsjust a bad crimp
thanks guys Ill look into it.
HKS Twins
make sure you made the right connection to start off with. I would pull the door handle switch and hook it up directly to that first to make sure the alrm is working properly and then follow the wire into the cars kick panel or run wires directly to the door handle where the lock and unlock is. What kinda of car is this? a supra? If so you are prolly using gthe blue and green for lock and unlock. First thing is first make sure you tagged the right wire then double check connection..let us know how it goes
1 - 7 of 7 Posts
