1 - 8 of 8 Posts
Initially when I was running the MAF I had the long Garden hose connected from the Air Idle control Valve to my intake ;
Now with the VPC installed there is no need for this tube bu heres the kicker; do I cap the Air Idle control Valve or leave it open and rig a filter up?
I was unable to find anything on MKIV.com or on Supraforums.
Thanks in Advance!
--chris
sidwin said:
just put a KN filter on the IAC. I wouldn't cap it.
sid
Are you running a VPC with the IAC filtered? Is this the definative answer on whether or not it should be capped or not, or is this from personal experiance?
Thanks!
--chris
the iacv just needs a breather as sidwin said... get a K&N filter
i have one too, its works and its neater than the line.
1 - 8 of 8 Posts
