·I am using VPC/GCC with a VPC harness, and the units don't light up when I turn the ignition key on to ACC. Harness plugs look nice and flush together, how can I check whats going on? TIA
Does the car turn over? Normally when the VPC/GCC don't light (at least in my experience) they aren't working.MONSTER said:I didn't splice anything, using HKS VPC harness to connect both units (they piggy-back off eachother). Not sure if I have to splice power/ground separately, but my guess is not. I'll try checking wires to see if there is enough juice for them to run.
Stage7 said:Wolf,
Check all fuses/relays (esp in the engine compartment).
Do the pumps turn on when you put the key on?
