Ok, well, I got the afc+vpc all wired up, however, I still need to put the resistor in the maf connector. can anyone tell me what pins to place the resistor in on the connector for the maf. I don't want to put the resistor on the ecu.
here are a couple quick pics of my custom glovebox install
Answering my own question
for anyone that needs to know. I managed to find the answer
stroker6
Looking at the pins of the MAF connector with the rectangle notch facing up, the resistor goes across the second and third pin from the right.
My 94TT is BPU+ and I just got a Haltech Elite 2500 to go standalone. Sticking with stock fuel (upgraded injectors though) for now, and would like to drop in a fuel-pressure sensor somewhere. Is there any easy spot to do that ? Maybe the banjo/union bolt on the existing fuel-pressure...
After I have installed all the new seals, BCsprings, retainers, locks and buckets,
with T-belt off, put crank at -10 btdc so all pistons are slightly down, install new BC 272 cams, install cam gears, torque cams as per manual. Then turn CAMS clockwise to tdc notches, and than turn CRANK to tdc...
I am about to repaint my brake calioers. I’m looking for ideas (my car is white).
Post your pics - try and show your car color - and let’s see what’s out there.
I will post after pics when I have some ideas.
Recently acquired a rhd supra and slowly starting the process of swapping things over. Got myself some glass headlights and wanted to swap bulbs while I’m at it. Been told jdm lights differ from usdm. Hard finding more info on this. Thoughts? Trying to find a quality hid system, seems LED isn’t...
