1 - 9 of 9 Posts
2JZ-Phantom
Hey guys, for those of you using the vpc, where did you install the air temp sensor and pressure sensor? Also does anybody have a pdf file of the vpc manual that they can send me please? Thanks
2JZ-Phantom
Thanks but I am already using the fuel pressure regulator line as a source for my greddy boost controler. Does anybody have another source for the pressure sensor?
So, they make a 4 way splice, even 5 or 6 lol
You'll be fine, you can also drill on the back of the manifold theres some filled holes you can drill and tap to use as alternate vacuum sources if you fancy.
Newbie
A lot of manuals or sources say "don't tap into the fpr". I just splice splice and more splice. I just unhook it and let the car idle. If I put my finger on that source and it pulls well, I'll use it.
As far as the temp sensor, the easiest spot is the IC (as close to the tb as you can).
anyone know if a 450 cc chip from a DSM will work?
are chips just CC rated or are they engine specific??
thanks
1 - 9 of 9 Posts
