I am trying to hardwire the vpc on a 96 NA OBD2(hotwire). I see differing inforrmation regarding one wire that connects to the afc input. I basically have 5 wires coming out of the vpc: black, red, brown, white, and gray. No yellow wire on the ecu/afc side of the connector
On mkiv.com it says connect the vpc yellow wire.
On a few diagrams here it says connect the gray wire.
Which info is correct?
Thank you.
Thank you.
