1 - 20 of 20 Posts
Search
I just got my VPC... would those of you who've been running this system take a look at what I purchased and make sure everything's there, and looks okay?
www.bouscal.net/images/vpc
also, does anyone have a pinout of what wires are what coming off the harness heading to the ECU... part of the reason i only paid 375 for it was that there was no harness... oh well, as long as I figure out what wire's what :) also, what do I set the dip switches for?
_ justin
Do You Even HKS, Bro?!?
Yours is also missing the 1/8" NPT adapter for the temp probe. HPF can get you that as well.
As Quickstrike said, you'll need the ECU harness (or you'll have to hardwire it)
Lastly, I couldn't read the Chip, so if you got it from Japan, you'll need a USDM chip, if not you're good to go.
Have fun
Kevin
LexusTico
:wtflol:
vpc:wackit: :sperm:
LexusTico
Justin said:
hahaha, wtf is that????
you tell us!! LMFAO!!! :lol: :lol: :lol:
Supra Fan
I remember hearing that you should use the 440cc chip if you are using 550cc injectors, because the 550cc chip makes things way to rich.
Search
Discussion Starter · #10 ·
Ahhhhh.... for some reason last time i viewed this thread the picture didn't show up so I didn't have the slightest idea wtf you were talking about, make sence now :p
I've heard that to, which is why i'm after a 440 chip :)
That harness cost me $126 + shipping from HPF. You don't really need the adapter for the tmep sensor, I just tapped a hole in the 3000 pipe to fit the sensor itself, works fine. Its 6mm x 1.25 iirc. Also make sure you have the right chip, and the dip switches are set right. The first time we started mine up, the dip switches were set for an RB26DETT.:)
Search
Discussion Starter · #12 ·
Okay, that price still isn't too bad, I just have to decide wether I want to pull out my emanage, e01, and wideband from the factory harness and re-wire it all into there...
as for the hole, that's what I was planning on doing... if I order the hanress I'll get the adapter to... i think its like 8 bucks *shrug*
do you have a list of what the dip switches mean? just so I can have them?
Digital Dreamer
Can you tell me for understanding purposes, you wire this box in, place the probes and sensors properly, and you can remove the afm, and run a straight pipe instead? No other modifications suc has controllers or computers?
eric
Search
Discussion Starter · #14 ·
eric
Yes, but an AFC/eManage is recommended as the VPC doesn't control fuel in the way an AFC/eManage does
Does anyone know which wires I need to hook up in order to install this without a harness? I don't want to buy a harness... That's that. I want to hardwire it, and would like to know what colors are what... I found 'em for the MKiv, but the MKiv uses a MAF not an AFM so I don't think the wires would be the same... Also, I need to know about the resistor...
Thanks, Justin
Thanks, Justin
Do a search on VPC and hardwire. I believe Alan has a site somewhere with a diagram for 89+. He probably has a link for the older ones too.
1 - 20 of 20 Posts
