1 - 2 of 2 Posts
Long story but it seems my car is not picking up the vehicle speed for my cruise. Also related to this is the 2 step(aem). My aem 2 step would cut in at any speed(its set to stop at 10mph). Once i bridge pin 5 and 6 I seem to have a vss(reading on aem) but still no cruise. This is a common problem in our cars(cruise not working)
My question is this what will fix this issue? Is the VSS located in the odometer cluster? Do i need a new odometer to fix this?
TIA
If you bridged pins 5 & 6 by the odometer and the AEM gets a speed signal then there is something else wrong with the cruise control.
Here is how you can TEST to see if you are having a problem with your VSS or something else. If this jumper did solve the problem, then splice the 5 & 6 wires together on the back of this plug.
Here is a picture:
And here are some other threads abou the VSS not working:
http://www.supraforums.com/forum/showthread.php?s=&threadid=20583&highlight=odometer+jump
1 - 2 of 2 Posts
