1 - 11 of 11 Posts
Stock Twins King
Curt
I have accumulated a bunch of VSV's over the years, and I never new which one went where. I always heard of people taking VSV's off that don't belong it that location. As an example, what is the difference between 90910-12114 , 12115?
So if it wouldnt be a hassle, could you provide the correct VSV PN per location.
TURBO
IACV=
EGCV=
EBV=
WASTEGATE=
FPR=
EVAP=
EGR=
Thanks,
stu
Stu Hagen said:
Curt
TURBO
IACV= 90910-12114
EGCV=90910-12127
EBV=25860-46060
WASTEGATE=90910-12115
FPR=90910-12014
EVAP=90910-12175
EGR= 17630-46060
Thanks,
stu
The vsv's have specific part numbers for specific locations.They might look the same but internaly are different.
Pricing:
90910-12114 Valve, List 195.66 Cost 145.89
90910-12127 Valve, List 60.87 Cost 45.02
25860-46060 Valve List 66.73 Cost 49.35
90910-12115 Valve, List 195.66 Cost 145.89
90910-12014 Valve, List 73.62 Cost 54.44
90910-12175 Valve, List 190.11 Cost 140.58
17630-46060 Valve List 109.00 Cost 81.28
Stock Twins King
Hey Curt,
I have a question on the 2 types of VSV's It says in the manuals that it is either "On-Off" type, or "Duty Cycled" type. I know what that means, but what I am wondering, if it is duty cycle type, and someone uses a on-off type, it woud burn out. Since a duty cycle could actually have current flowing thru it more often, and larger windings, the on-off type could'nt handle the constant draw? It is also apparent by the larger sized VSV's, that they are the Duty cycle types. When it comes to the wastegate VSV, i'd imagine that there is voltage on the hummer almost full time!
Stock Twins King
Discussion Starter · #10 ·
Curt,
Things are not correct here??? Please verify> I have EACH VSV in front of me, and this is the PN's I see for each use: (turbo related only)
IACV------- PN: 90910-12126-A ???
EGCV------ PN: 90910-12127-A $ 45.02
EBV-------- PN: 90910-12114 $145.89
Wastegate PN: 90910-12115 $145.89
Your PN or the IACV is wrong??? as well as the EBV?? Please correct me if I am wrong? I am giving out bad info if your referances are incorrect. Also, check the pricing.
Stu
1 - 11 of 11 Posts
