1 - 9 of 9 Posts
looking for several parts for the 2jzgte vvti . not sure of the parts numbers. let me know what u can get. thanks for your time man !!
VVT gear
vvti oil control filter
vvti solenoid
vvti timing gear
vvti valve cover gaskets
vvti coil/plug cover
vvti upper & lower timing belt covers
im using an 2jzgte aristo vvti head on a usdm block. im looking to refresh the vvti parts with new oem and im missing some things like the plug cover, timing gear, etc. thanks
The GTE VVTI components ( gear, solenoid, filter, timing gear) should be the same as the NA VVTI components. As far as the covers and gaskets go, I'm not sure. Was hoping u could source those as well. Let me know what u find. Thanks again for your time
Anime Dork
I'm going to have to look up this stuff through the jdm catalog since i do not have access to the lexus catalog. Usdm toyota supra na's never came vvti only the is300.
Anime Dork
15330-46011 valve ass list 129.44 cost 97.08
11213-46030 gasket, c list 16.93 cost 12.70
11214-46011 gasket, c list 19.29 cost 14.47
13050-46010 pulley as list 239.89 cost 179.92
11303-46040 cover sub list 66.14 cost 49.60
11302-46031 cover sub list 70.39 cost 52.79
these are all the parts i could find that i can get.
Sorry about THAT. I meant by NA, the 2jzGE found in the IS300 w/VVTI. Can u also get me a quote on the crank timing sprocket from that motor? That should be everything I need. Thanks again man !
1 - 9 of 9 Posts
