1 - 20 of 26 Posts
Lag = Foreplay
Ok so i have been searching on the web for a while now trying to find out just how much power a W58 tranny can handle. I have comeback with some crazy different numbers some people saying its only good for 300 others saying it can hold up to 500. So what is it guys i need to know because i am about to put my 87 turbo back together and i need to know if i will be ok with my good ol W58 5spd. I am looking to make 400-450 HP.
WhorE
well if you goto spec clutches, they have a clutch for a w-58 that can handle 500 ft lbs :ugh2: I wouldnt go too much hp with the w-58. I have a gte matted with a w-58 and a spec stage 2 clutch. No problems here so far, but Im only running intake and exhaust. If I plan on doing any more mods Im really thinking of swapping the w-58 for an r154. just my 2 cents. You abuse something enough it will break.
Wayne
Can't wait for Spring!
i'd be interested to put my car on a dyno now, but i'm running 15psi on my 7mge w/ the w58. No clue as to power, but she gets up and goes...
7MGTE CRESSIDA PWR!!!
w58= fine for daily driving.... after you start abusing it or launching it...... Say goodbye w-58.... its good for about 450 hp....
what would jesus drift?
basicaly, if you dont want to deal with a broken tranny, opt for a r154 to begine with it will take motre abuse...
i had a w58 laying around i picked up for 50 bucks to replace the one in my Celica..
i already have a few mods done to my car.. so i figured why bother buying a clutch for a 58, then to have to purchase another when i went r154..
"basicaly, if you dont want to deal with a broken tranny, opt for a r154 to begine with it will take motre abuse..."
Not true by a long shot. The W58 is just as strong as the R154 and shifts much better.
slowly giving up...
i believe i'm hovering around 300rwhp as of right now. (i'll find out on sunday, at the dyno) i'm on the w58 and it's holding like a champ. just make sure that sucker has gear oil in it, and you should be good to go. by the way, i have a lead foot. ;)
-shaeff
Boost Addict
ditto....for almost 27k now. But, I don't abuse/race mine, just DD with an occasional leadfoot moment :p
239RWHP @ 9PSI
how long have you ran your 1/2na-t with the w58? i was reading dr jones page and his blew not long before he did the conversion.
slowly giving up...
i've got about 2k on this tranny. here's my info from the dyno today:
back from the dyno. i couldn't get the profec B to function properly, and couldn't find my dr. jonez MBC either. i have the wastegate shimmed to hold boost until redline. i was running 10psi, creeping to 15psi. i dyno'd in fourth gear, open downpipe. stock CT-26 with mild shaft play and 3 chipped impeller blades. :)
it was a mustang dyno, and it was calibrated by putting the car in (i forget) gear and holding it steady at 3k rpm.
i'll post the sheets tomorrow, as i have to get my dad to scan them for me at his job.
here are the numbers:
1st pull:
AFR: dropped to 10.9
torque: 280
HP: 275
i then dropped the fuel pressure about 6-7psi and got:
AFR: 11
torque: 292
HP: 287
then dropped the fuel pressure a tiny bit more and got a best of:
AFR: 12.2
Torque: 295
HP: 289
remember, this is boosting 10psi, then creeping slowly to about 15. (closer to 14)
i know i could have hit 300 if i had more time to prepare. too bad it's been raining for the past week and a half!
MODS:
1986.5 chassis, still on the w58 with my own custom SOGI short shift rethreaded for stock knob, '89 7MGTE, Clutchmasters Stage III, Fidanza Lighweight Flywheel, Lexus AFM, RC 550cc Injectors, Boost Reference Aeromotive Adjustable Fuel Pressure Regulator with Fuel Pressure gauge and stainless steel braided lines, pulsatoin damper removal kit and j-tube bypass, Walbro 255 Fuel Pump, Megan Racing Boost Gauge, Becauseican Divorced Wastegate Downpipe, 3" RS*R Concept Cat-back with resonator removed, Cometic 1.4mm MHG, ARP Headstuds, 1mm Oversized Valves, Dr. Jonez Manual Boost Controller, Eibach Pro Kit, Koni Yellows, Upper Hardpipe/BOV, B&M 11x8 oil cooler, B&M 180* thermostat, oilfilter relocation kit, Greddy oil catch can, MKIV TT rims. 3400lbs with driver *not installed yet...* MAFTpro- speed density
1 - 20 of 26 Posts
