1 - 7 of 7 Posts
Ok I have been breaking in my supra for the past 2 days. Everything is great except one issue. After driving the car for a while, like 20 minutes the fuel pump will get very loud, when this happens it drop s some base pressure and if you try and boost theres no fuel there. If you shut the key off and restart the car its good for another 20 minutes. I cleaned out the tank a few eeks ago and instlled the new pump, also bypassed the resistor, and removed the charcol canistor.
I vented the fuel cap today and it still does it. Someone told me his nissan did the same thing. He wired a 10gauge wires from the battery with a relay for the pump. never happened again? However if it was low voltage why would it get louder. Noramlly i cannot even notice the pump. When this happens it whines really loud?/
just because it is getting louder doesn't mean it is pumping faster, might not be enough amperage tho, basically the thicker wire accomadates more current.
man thats almost the exact problem im having...does it bog when quickly hitting the throttle after awhile driving?
My car was doing the EXACT same thing. I have an A1000 aeromotive pump. Solution=new fuel filter. Mine was black as coal - problem solved.
yea i put a brand new toyota filter...i think im going to solder the wires this time...
1 - 7 of 7 Posts
