·Well coming home today, she bit me back...I was cruising at about 80 @ 3k when i feel a drop in power. I get off the exit and I thought i was out of gas and tha tank was reading wrong...i get gas, make it home hobbling at 2k rpm. I check FP and I'm making only 10psi when the key is on. (Car not started) This is down from 45-50psi.
I pull the tank cover to find that the secondary pump line hose has come off the pump. I reattached tightening the clamp very hard. I button everything back up...turn the key on, after about 5 second i hear the pumps do something and the FP drops, I open the tank again, find the same problem. Open everything back up, do the same, make sure everything is extra tight, test it with the tank open, works fine, close it up..after about 15 seconds testing both fuses and FP making sure everything is right, and just when I thought it would be fixed, it happens again! I have everything open now and I honestly can't figure out why it's doing this, the fuel system has been on the car for 15-18k miles.
It's a SP FUel system on a Single. Any Ideas at this point to solve the problem are welcomed other than more hose clamps, because the car hasn't had a problem for this long why all of the sudden? I thought a clogged fuel filter might have done it but after talking with numerous people noone came to that conclusion.
Any help is appriciated....
