swearitsstock said:Just a little update... car got dynoed today
93 octane
13 psi boost
390rwhp on auto with 3600/3800 stall
its a good number for that low of boost... i also found out 2 days ago that my trans was slipping during that dyno (trans went a couple days after being dynoed)coronabeer4eva said:Impressive, is that what you were kinda hoping for?
swearitsstock said:its a good number for that low of boost... i also found out 2 days ago that my trans was slipping during that dyno (trans went a couple days after being dynoed)
i expect mid 400's on pump gas and low 600s on race fuel after i get the fuel system
it should be enough to get into 9.90s
I thought the 800 was supposed to make more power than the 63?[email protected] said:SPssgt800w is availible in a .81 and a .96 A/R.... swearitsstock has the .81
boost should come on a bit sooner with this turbo over the 63 but you will sacrifice just a bit of top end with the 800w. But after taking a ride in Jons car..... who cares about 25 HP on the top end.... when it comes on, it hits hard!!
The best part is the price.... $1150 coated and Polished!!!! you cant beat it!
well on precisions website the 63 is rated to 745, the 67 is rated to 780, and on garrets website, the spssgt800 is rated to 800...HotSoup said:I thought the 800 was supposed to make more power than the 63?
Jason
thanks man, it seems as this may be the new "magic" turbo. It is small enough to give alot of boost off the line...which should net 1.4X 60fts AND the RWHP to trap 135+....I think this turbo is capable of running in the 9.8 range easily.swearitsstock said:well on precisions website the 63 is rated to 745, the 67 is rated to 780, and on garrets website, the spssgt800 is rated to 800...
now depending on exhaust housings, wheels and so forth, these numbers can all be changed around slightly but all 3 turbos are in the same range
well the current setup im going with is a really low stall speed with a small shot of nitrous (on the footbrake... because i wanted a forward pattern th400 to retain engine braking)... all on antilag with a 2 step setup... this similar setup let me build 14-16psi on the line with the stock twins and cut 1.5 60's on drag radialsHotSoup said:thanks man, it seems as this may be the new "magic" turbo. It is small enough to give alot of boost off the line...which should net 1.4X 60fts AND the RWHP to trap 135+....I think this turbo is capable of running in the 9.8 range easily.
Jason
the 29.5s fit on my car due to quarterpanel modifications i did... when i had the bodykit molded, i had them enlarge the opening (basically the wheel well has a larger circumference) and extend the fenders 1 inch...Evill Supra said:Wow,
That looks like a great set up. I'd like to try something similar sometime perhaps as well. Will those 29.5 inch tires fit without rubbing? That seems like a lot of tire, which may make it more difficult to 60ft since you are adding gear.
Keep us up to date with your set up.
Steve K.
